GPX600R Carb problems.
I went out for a blast to day now that the snow has gone. Filled the tank up with gas and away I went
Had only gone 18 miles when she just died so I coasted so a stop at the side
Of the road had a good look round the bike could not find any obvrous things wrong
Thumbed the starter a couple of times but she would not start the only way I could get her to start was with the choke full on once running took the choke off and set of for home.
Did the same thing about 10 miles later
Sat there for a couple of seconds pressed the starter and away she went again.
This problem seams to happen if I give it a big hand full for any length of time.
Now I no that the carbs need balancing but they are not that far out.
When I finally got home I took the carbs of adjusted the pilot needles to the settings in the book
Put it all back together and went out for a test run.
Ran ok from low speed right up to redline with out a hint of what it had bean doing
Any one have any ideas
