In the cap i cannot find the air vent. the cap is square, and i see nothing beyond the seal .. :shock:
where is?! these things make me feel like a fool... :redface: , after the carburetors sync :redface:
I think it is clogged and want to clean :smile:
Ah, a question: I installed years ago, a solenoid (its correct ''solenoid''???) for moving gasoline (the tap is not working on PRI position) connected to the ignition key. everything perfect, but the hose depressor is still connected at carb n°2 , it is better to remove these tube and close with a cap the vacuum line also in the 2° carb..????
gasoline goes equally.. but i still have the useless tube, what do you advise me to do? :smile:
thanks very much to all :smile:
SORRY FOR ENGLISH
SORRY FOR ENGLISH
