Hi
I have a gpz750 that I bought about 2 months ago. It ran fine at first, although occasionally took a while to come down from high revs at idle. After a while it started to stall when idling and then get stuck on around 7,000 revs (constantly not jumping about) once the throttle was opened.
I have pulled out the carbs and cleaned out all of the jets etc. Today I put the carbs back in and now it won't start at all! No fuel is coming from the tank even with the tap set to 'prime'. I think it may be a vacuum leak - any ideas? I've also checked the exhaust system for leaks and there aren't any. Also the previous owner but a ZX-6R Ninja exhaust on it, would this make it run too lean?
Thanks
Thanks
