--I recently got ahold of a 83' GPZ750. The engine turned over fine so me and my dad took apart the carbs and cleaned them thuroughly first. After that, and some minor airflow/gas flow problems, we got it cranked and running. . .
--the only problem is, you have to choke it all the way out to crank it and it revs high, then as you put the choke in it revs lower and lower until it shuts down. This happens even when its been running for an hour or so give or take, so its plenty warm.
--When you go to gas it while its idling, which is about 2k rpm < not sure what it should be at > it bogs down before it revs and sometimes shuts down, etc. . . Its like the air is cutting off when i gas it or its not getting enough gas / too much gas is flowing, i'm not sure, this is my first bike.
--anyone have any input on this engine or anything i should check/replace. . . we haven't looked into the block really itself yet. . . and we're trying to get it used to running again and lubed up, in hopes it'll start running smoother. . . any ideas would be appreciated.
---Also, anyone with any gpz750 parts/body pieces that are in decent shape, let me know, i may be needing it.
Thanks anyone,
- Jason
Thanks anyone,
- Jason
