1 - 5 of 5 Posts
I have a grinding sound when going down road if I turn the steering to the right. I just replaced front and center u-joints and two yokes on front shaft. Front wheel bearings and both front axles have been replaced. When I turn to right while driving I hear the rumbling, grinding sound. Turn to left it quits. I have jacked it up and turned wheels, shook them up and down and side ways, no slack anywhere. Ideas please.
Super Moderator
Welcome to the forums HotRod.
You have provided a good summary of what's been done so far.
However, when asking for help please include the year and model of your machine and a brief history of the machine, ie how many miles on it, how long you have owned it, what kind of use it has seen, etc.
Sorry, it’s a 2005 year - 620E - 3010 - Gas, with 896 hours on it. I have had it for 4 years myself. It wasn’t running when I bought it. It had fuel pump issues and carburetor issues. I corrected these my self with a rebuild kit for carb replaced fuel pump and cleaned and sealed gas tank. I think maybe I have found the problem but have not taken it down yet. The front shaft where the first u- joint is has noticeable play up and down when I push up and down on it. I can’t tell if it is the bearing or front yoke shaft wore out on the end. I need to pull the skid plate where I can see it better. How hard is it to change the yoke bearing or for that matter the yoke it self? I don’t know why turning to the right I hear this sound and not when turning to left. I think I will remove shafts from front to rear then drive and see if I hear the sound. Also I notice the swing bearing has up and down play in it. This mule is used on my farm but not a lot of hard work is done with it. I run from pasture to pasture and once a month I pull a 500 pound hay rack that is on skids down a dirt road about 150 yards. That’s about the only time the 4 wheel drive gets used. The people that had it before me let his kids drive it and they drove it in the woods a lot and roughed it up some. When I got it he had just spent $800 on tires and hoses and a tune up. He said it run about 20 minutes and quit.I bought it as is condition and spent about $300 on it That’s when I found the fuel pump starter switch bad plus carburetor and tank problems. I haven’t had anymore major things happen until now. When I figure out the front yoke issue with the loose up and down motion, I’m thinking I have to change out the bearing and front yoke as well as the swing bearing. Thanks got your reply back to me.
Keep us posted on the progress. Maybe post up some pix when you get it apart.
Hopefully tomorrow I can pull the propeller shaft out. Will it hurt to test run for the noise sound then? I mean remove shaft front front to rear and drive off. Then I can check shaft splines and yokes. I had one spline on front u-joint that was slipping so I welded it to the yoke. This would be the spline after the front U-joint. I don’t think this has caused this problem. I have been reading where air pressure in tires can cause a popping sound when using the 4 wheel drive. I’m checking tire inflation also tomorrow. I think they recommend 12 in front and 24 in rear. I know I have been running tire pressure even in front and rear.
1 - 5 of 5 Posts
