Hello everyone, so the situation is I'm in the middle of a motor swap from a 1500 to 1600 and after all my research I didn't see that the mean streak only has 1 stator and the classic has 2 stators. Since when my 1500 motor went out it destroyed the outer stator and stator rotor/ magneto as well I can't transfer the dual stator setup without buying all new parts. I'm going to solder the two female adapters together to make it a single setup but here are my questions.
1. Can this be done going from 2 stator to 1 in the case of wiring them together?
2. Will I need to also wire the two rectifiers/ regulators into one as well??
Thanks in advance.
Thanks in advance.
