1 - 7 of 7 Posts
I would like to find what set will fit the 04 1500, I do have the Cobra Light bar and turn signals, Not sure if the Kawaski Lowers will work, The Memphis Shades, don't look like they will fit
any one have any info??
thanks
Dave
· Official BTK Forum Pot Stirrer
Not sure if the F&S will fit, they do make lowers for use with or without lightbars but I'd think they were designed for the F&S lightbars but you could always call Laurie at Beartooth Kawasaki and ask
I've looked at both of those sets of lowers, are those moxy's bigger than the F&S
Aren't the Edmounds lowers a replacement piece that inserts into the oem Nomad lowers bracket? Would they work on his 1500? Edmonds only list the Nomad on their page.
Do you have a F/S windsheild Daniel?
Phatboy
Yeah, the Edmonds bolt into the existing mount on the Nomad. Can't say about the 1500. Send an email about the Edmonds fitting the classic..... Sid's a great guy and will give you the scoop.
A friend bought the Moxie lowers for his Volusia. They seem to be a bit bigger than the F&S stock lowers on my Nomad. They attached to his fork covers via 2 u-bolts that go around the cover and throught the lower. As you can imagine, the force of the air rotates the lowers back so they sit at an angle to the fork. For my money, I'ld look for something other than the Moxie lowers.
1 - 7 of 7 Posts
