1 - 1 of 1 Posts
My mojave is running rich at idle and sometimes will not idle. I have taken the carb off several times and clean out with automotive type carb cleaner. I have adjusted the valves but they may be on the tight side of the adjustment specs. I read in the shop manual that the starter plunger could cause this problem also? Thanks for any help. :?:
1 - 1 of 1 Posts
