1 - 2 of 2 Posts
Hello everyone! i just buy a Zephyr 750 1991 but i need the generator cover and the points (pulse) cover too, maybe the stator and flywheel (magneto), the pulse one is interchangeable wiyh gpz and kz from the 80's, but i wonder if the generator cover is the same? I read than is almost the same engine than KZ with few changes, but anyone knows if KZ 750 generator cover, stator and flywheel will fit on my Zephyr?? I'm in México and is really hard to find the Zephyr ones, but KZ parts are available.
A guy from Spain tells me that GPZ generator cover from the 80's will fit, GPZ fits KZ too right? so i assume both are compatible... can you help me with this issue? zephyr.jpg zephyr generator cover.jpg kz750.jpg
Thanks in advance for the help
So the generator cover is unique to the 1991-93 Zephyr 750 but that could be due to styling. So I checked the gasket since the gasket will determine the bolt spacing. The gasket is common to about 30 different bikes including 80's GPZ.
But this does not guarantee that the generator cover will fit, but at least the bolt hole pattern is the same. What worries me is that the stator is also unique to the Zephyr so if you are going with a GPZ cover and a GPZ stator you need to make sure the stator will fit properly inside the unique Zephyr flywheel. The exact fit Zephyr covers are available and that might be your best option.
1 - 2 of 2 Posts
