ZX10 Undertail
Hotbodies ZX10 undertail requires trimming several plastic parts, re-use of the stock tail light and moving the key lock from the side (2008 ZX10) to the middle...not a simple fitting. After all that, you will need to drill holes to attach your license plate using two small L brackets. It looks like Hotbodies refitted another part (from ZX6 probably) and repackaged it for the ZX10 by changing some labels hence the extra installation efforts. A lot of money for basically a piece of plastic. Be careful of online ordering sites as, irrespective of their published return policies even if the part doesn't look right, the restocking fees might be imposed despite your protests. Indysuperbikes was good about a return when the manufacturer mislabelled a package; not everyone is as accommodating...kneedraggers.com handling of a similar order was not so great.
