Well first off, what do you think would be a good price for a complete 89 600R roller (minus engine + plastics)?
Also, when my 600R motor was shipped to me it fell forward on the pallet and put a little crack in the valve cover (think epoxy/or JB-weld would fix this little crack?)
And also when it fell forward it cracked one of the cam holders (one of the 6 that have a threaded hole to bolt the valve cover to) any idea where i can get another one? i checked the Kawasaki Parts Fiche and couldnt find it :(
and this one i just found cracked :( stupid DHL
Anyhow, i just CANT find a part number. :eek:
and what is a good oil to run in the 600r?
TIA guys!
AZ's Official Mechanic
Re: Hey guys a couple of questions about 89 600R *pics added
tissan said:
Well first off, what do you think would be a good price for a complete 89 600R roller (minus engine + plastics)? not a whole lot maybe 500$ :roll:
Also, when my 600R motor was shipped to me it fell forward on the pallet and put a little crack in the valve cover (think epoxy/or JB-weld would fix this little crack?) -clean it with ether and put a nice thin coat of JB-WELD on it. let it dry for DAYS. preperation is the key.
And also when it fell forward it cracked one of the cam holders (one of the 6 that have a threaded hole to bolt the valve cover to) any idea where i can get another one? i checked the Kawasaki Parts Fiche and couldnt find it :( and this one i just found cracked -ya didnt look hard enough cause they should have it. also might want to check with www.ronayers.com www.bikebandit.com and your local dealer
and what is a good oil to run in the 600r? -i run YAMALUBE in my bikes along with a STOCK filter (no aftermarket filters no much how cheaper)
TIA guys!
thanks alot QKENUF4U, i accutally ended up paying 185 shipped for the whole roller :D
Other then missing most the bolts and the gas tank is dented its not to bad.
TA
