I have 1997 ninja zx6r. when i start it it rides ok. but when it warms up, the rpm goes up to about 5k rpms and stays there. any suggestions?
AZ's Official Mechanic
sounds like you have a vacumn leak around the carb boots or elsewhere. take some carb cleaner and spray each carb boot individualy and listen for the idle to rise. dont spray a ton or it will just get sucked into the airbox and give you false readings.
thanks for the reply. ill try that tonight.
