1 - 6 of 6 Posts
Hey guys just something for those that know what's what when it comes to a 12 volt charging system...... but lets say I threw a 100 Watt high beam 65 Watt low H-4 in my '80 kz1000 ltd. Could that make the bike not charge the battery properly and seem to be a stator or rectifier/regulator issue? I am only looking to get a little more from the headlight so I can feel a little more comfortable riding to and from work in the dark in south central minnesota.... I have had more than a couple deer wind up in my path (thankfully never on a bike) while traveling around the mankato area and just want to have the best light I can to spot the little buggars before they wind up in my lap... just curious if anyone has been there and done that before with bad or good results. Thanks for your time
Try this test:
Alternator Testing For the Older 4’s(Z1’s,Kz 900’s, Kz1000’s,Kz1100’s and GPz1100’s).
To check to see if the alternator is working you need to follow these simple steps:
1. Fully charge the battery as this will be the power source during this test.
2. Disconnect the Regulator/Rectifier at the plug that has the six wires in it.
3. Start the engine and let it warm to operating temperature.
4. If you're worried about overheating, position a large fan for cooling the engine.
5. After the engine has reached operating temperature, have a helper assist you, and using a multi-meter, read the output at the three yellow wires (or the alternator output wires)at the disconnected connector.
6. Raise the engine speed to 4000 rpm, and see what the three YELLOW wire combinations(or any alternator output wires) are(1-3,2-3 & 1-2). The output will be around 50 Volts A.C.(Alternating Current). BE CAREFUL, AS THERE IS A SHOCK HAZARD HERE!!
7. If any of the combinations are low or non-existent, the stator(wire windings) are bad and must be replaced.
Some of the older Z1’s and KZ900’s were phase sensitive, so check the wire colors carefully.
8. Using an OHMETER, Check the three wire combinations again, looking for a reading of 0.36 - 0.54 OHMS. If the readings are above or below, the stator may be bad and need replacement
9. Before ordering a new stator, check the connections from the stator as there are electrical "Bullet" connectors that may be damaged or dirty.
Inspect the wiring for signs of shorting or overheating too. Z1 Enterprises, Inc. - Specializing in Vintage Japanese Motorcycle Parts sells replacement rubber grommets for the alternator output wiring, they get hard and could leak oil after a while.
10. Check the wiring coming out of the grommet as there have been situations where the wires were damaged causing a short(I.E. twisted together with insulation damage).
11. The sprocket cover may have to be removed to access the electrical connectors coming from the alternator and possibly the left foot peg, and shifting lever will have to come off.
The following is a step by step procedure for replacing the alternator stator(wire windings).
Alternator Stator Replacement On the Older 4’s
Source for replacement Stators:
A. ElectroSport Industries - Motorcycle, Dirt Bike and ATV Aftermarket Electrical Parts (They have a trouble shooting page)
B. Custom Rewind -- High Quility Remanufactured Motorsports Electronics, Rotors, Stators, Ignition Systems
C. www.rmstator.com
D. www.ricksmotorsportselectrics.com [4]
E. www.regulatorrectifier.com
1. If by testing either by checking the output voltage from the stator or by using and ohmmeter for resistance and the stator is determined to be bad, replacing the stator is not a difficult job.
2. The motorcycle owner should have on hand a replacement alternator gasket as it will tear on removal and leak if reused.
3. Put the bike on the center stand if possible and lean it to the right to minimize the oil volume that could come out when the alternator cover is removed.
4. Have selection of Metric wrenches and sockets along with Metric Allen keys to be able to accomplish this repair. ¼" and 3/8" ratchets and extensions may be needed along with Allen bits.
5. Remove the gear shift lever, the sprocket cover and possibly the left foot peg assembly.
6. A catch pan for what little oil will be lost should be positioned under the alternator on the left side. Newspapers will soak up any oil lost or some kitty litter will do as an absorbent.
7. Remove the alternator cover fasteners, some bikes use a socket head cap screw(Allen type) and others use the Phillips head type, the #3 screwdriver bit fits best for those. Use a small dish or can to collect the removed fasteners from the parts to prevent loss/damage.
8. The alternator stator is secured to the inside of the cover usually with three Allen headed bolts, Some bikes may have Torx style fasteners, Remove them and disconnect the three yellow wires that have bullet connectors on them from the bundled wires inside the sprocket cover.
9. If your bike has some color other than yellow for the alternator output wires, make note of what goes where as the older Kawasaki’s were phase sensitive in regard to the regulator/rectifiers.
10. When installing the replacement stator, clock or position the output wires and grommet so they fit into the small port under the alternator cover without being pinched or damaged.
11. Tighten the three Allen or Torx fasteners, securing the replacement stator to the cover. I like using the BLUE Loctite # 242 for hardware that can be removed with hand tools.
12. Remove the old gasket from the mating surfaces of the alternator cover and engine case by scraping with a piece of sharpened plastic like Lexan or Plexi-glass as these will not gouge the soft Aluminum
Cases. Avoid using a metal gasket scraper for this.
13. Position the alternator cover, checking for pinched wiring and install the fasteners with a little silver anti-seize on the threads, tightening to the correct torque.
14. Connect up the output wires to the mating female bullet connectors and while you’re in there, check the routing of the wire bundle that runs through there.
15. Inspect for signs of heat damage to the wire insulation and vibration damage too.
16. The side stand switch, neutral switch, and oil pressure switch wiring are all bundled with the alternator output wiring running above and behind the engine output sprocket. This bundle runs in a channel as it goes up toward the various electrical connections.
17. The regulator/rectifier plug on the 80’s bikes usually has six wires in it:
A. One (1)WHITE with RED stripe, this is the bikes main power wire usually 12 gauge in size.
B. One(1) smaller Brown wire, probably 18 gauge or so, the voltage sense wire for the regulator/rectifier, helps keeping it from overcharging the battery.
C. One(1) BLACK with YELLOW stripe wire, part of the ground circuits, maybe 16 gauge in size.
D. Three(3) YELLOW wires,maybe 14 gauge in size, the alternator output wires going to the regulator/rectifier which converts the Alternating Current(A.C.) to Direct Current(D.C.) using rectification, producing the power to run the motorcycle and charge the battery.
18. Reinstall the sprocket cover, again checking for pinched wires before tightening. Install the shifter on it’s splined shaft checking for proper location, and the left side foot peg assembly.
The old and well used electrical formula is called WIRE where:
WATTS is W
I is current
R is resistance
E is voltage
If you have two known items, it's easy to figure the third.
Let's use your 100 Watt high beam as an example or W/E
100/12 or 100 Watts divided by 12 volts is 8.3333 or 9 AMPS.
To figure E (voltage) use W/I or Wattage over Current.
To figure I (Current) use W/E or Wattage over Voltage.
To figure W (Wattage) use ExI or Voltage times Current.
To figure R (Resistance) use E/I or Voltage over Current.
At low rpm the charging system may not produce enough voltage/current to replenish the battery. Electrosport makes an overwound stator that will produce a higher current than what the stock one does at these lower rpm's.
Try this test:
C. www.rmstator.com
WATTS is W
I is current
R is resistance
E is voltage
This space for rent
Short version is if you put a 100 watt headlight in your 1980 KZ1000 you are going to run the battery flat. The alternator only puts out a total of 280 watts max.
Discussion Starter #5
Thanks guys. On a related note anyone ever play with the idea of hid projectors in something this old....? Probably more work than its worth but I'm just curious as to weather or not its been done
At KZrider.com - Home a member named "Octar" put a HID set up on his GPz1100 (he re-bored the engine to I believe 1300) Another member"Loudhvx" dabbles in motorcycle electrical circuits.
If your IC Igniter goes out, "Loudhvx" designed and built a replacement using off the shelf GM electronic modules and has used them for many years on his GPz 550:
General Motors HEI Ignition Module For GPZ550
It's useable on any of the Kawasaki's with the mechanical ignition advancer.
1 - 6 of 6 Posts
