Have you used the horn on your bike much? Is it required by the Department of Transportation, when you received your tags and registration was it part of the requirement to ensure that it worked? They are required, but are they loud enough to command attention on the open road, Interstate, or in the city? I understand that Manufactures must provide at least the minimum requirement for The DOT, but are those "Minimums" sufficient for you? I have the cart in front of the horse on this topic because I neglected to research with Beartooth Kawasaki before starting this topic. I AM not happy, and do not believe that the Factory horns are sufficient for ALARMING other vehicles (cars, trucks, and other bikers), but I do know that there are aftermarket horns 12Vdc, like Fiamm with their Dual Horns that provide 132-135db level horns. That is REALLY loud, but IF you have to and are in a situation where you need a horn, don't you want to be heard? Is the cost of a pair of horns so expensive that you can/want to overlook the cost? IF you need to use the horn, you need to be heard! This is my Soapbox subject for this week...I hope that you think about it, even share this with your non-forum friends....you know...the same could be said about most cars and trucks...
