Jade said:
In trying to define the direction that I will go with the custom job on my Meanie I have become dissatisfied with the available custom pipes and am considering having some made.
But here is what I do not know. Are most custom pupes just a 'bent tube' or is there more going on?
$1000 is way too much. Should not be more than half that price.
Not bent tubes.
Stock pipes nowadays are made up of several components; headers, catalytic convertor, in some cases an O2 sensor, a hidden middle chamber or bypass where the two pipes share the load from whichever cylinder is firing and finally baffles to both muffle and create more back-pressure. Most aftermarket pipes get rid of everything bar the baffle, albeit a less restrictive one. Unless re-jetted or retuned with an aftermarket ECU you get lotsa popping and backfiring.
Pipes on show bikes are usually just bent plumbing. These bikes are hard to start, almost unrideable and cop and abuse magnets.
Whatever pipes you get, I'd recommend you make sure it accepts some form of baffling otherwise even you'd complain.
Modifying ready made ones sounds a good idea. The mounts would suit and you can get someone to do some cutting and rechroming to turn it into something different.
Many riders keep the front half of the pipes and custom build or tack on a different rear end to create a whole new look.
Good Luck.
