I'm still confused on which jet sizes, needle, and screw settings I should use.
I have a 95' VN800A with aftermarket pipes.
I'm going to install an open element air filter, Thunder kit, but I don't know what size jets to use.
Does anyone know what other people are using with a similar setup?
I need to know:
Main jet
Pilot jet
Stock or aftermarket needle
Shims and location
# of turns out on screw
What pipes you are using
If you are using a modified air box
Thanks again,
Dwight
I need to know:
Main jet
Pilot jet
Shims and location
Thanks again,
Dwight
