In the process of installing new brake pads on the front of my 2009 610 4x4 mule. The drum is a semi-press fit with the front axle. I removed with a hub puller but i can not figure out to reinstall the hub. I even tried with the brake pads off thinking maybe the new pads were the problem but no difference. I can't get it on far enough to get the hub nut on thinking that i could push it on the spindle with the nut.
I really would appreciate any help, thank you.
