got this bike for 200,
needed a carb clean I got it running but leaks gas from the carb I checked it and the flout needle was damaged, so I’m thing about buying a pwk38mm carburetor I’m thinking it will fit, also I’m thinking about painting the hole bike black and sanding down the gas tank and putting bondo in the dents, also need to now why the vin is 12 numbers on the front of the frame
also the guy said it was a 1977 but I’m not sure.
