1 - 2 of 2 Posts
I have cleaned air filters and WD40'd the carb and adjusted the idle screw.
Seems to idle ok sometimes but other times wants to die or rev higher so I am always working the gas peddle. The cable is lubed and fine. I will try Seafoam or something similar. Any fix ideas would be appreciated. Other than that she goes pretty good. Thanks
AK Cold Start Specialist
It might be your valves. They can do this if they're tight. It causes an erratic idle if it's bad enough. I'm about to go check them on my friend's bayou, which idles really high and he's already done what you did.
Good luck.
1 - 2 of 2 Posts
