I just picked up a Mule model 2520 kAF620B
It has good spark and I cleaned and rebuilt the carb. It will not start, it backfires, as if the timing is off. I replaced the ignition module and no change. I tested the pickup coil resistance and they both were 115. Compression is 190 and 195psi. The timing marks on the flywheel line up with top dead center, but the flywheel magnet is not near either pickup coil? Doesn’t the magnet trigger the spark when it passes the pickup coil? See picture
How can it trigger the coils if the magnet is in the middle. Should be firing #2 cylinder based on timing marks? How is spark triggered if not by magnet??
