First off sorry for the double post(posted in vintage as well, did not see the mechanics forum down here)
I hope you folks can give me an answer..
The bike in question is a 1986 ZN1300 Voyager converted with a Lehman Trike Kit. We hooked a batttery booster onto the battery to start the bike, bike started all gauges were working (has the the digital Led type) all gauges were working, started the bike backk up a few minutes later and none of the instruments were working. We checked all the fuses we could find. Located on the right side of the seat.
Is there a fuse for the instrument panel? Where would it be located? If not is the panel fried? Thanks in advance for your help.
John
· AZ's Official Mechanic
there should be a fuse for insturments but you should have found it in the fuse box. gonna have to pull some plastics and make sure everything is still in good shape and not FRYED/burned/broken/unhooked etc.
good luck
Thanks to everyone that posted, found the problem yesterday. There is a 30 Amp main Fuse and 1 Amp main fuse, the 1 amp fuse runs the Led dash. The fuse is located on the left side of bike and is an inline fuse.
Have a good one
John
