2005 VN2000
13000 Kms
Anyone had this problem yet?
The neutral light won't come on after engine is hot (approx 15mins riding). The transmission actually goes into neutral so the issue isn't there. Once the bike has cooled down it works okay. I'm a licensed mechanic so I figured I would delve into the problem.
According to the Kawasaki service manual there is a "gear position switch" inside the right side transmission cover. This switch provides input to the injection computer so it can adjust fuel and ignition depending what gear the transmission is in. I decided to test the switch as it should provide a ground when the transmission is in neutral. Sure enough it's open circuit when the bike is hot and closed when it's cooled down.
So I'm guessing that either the switch is bad or there is a mechanical problem with the transmission that is not activating the switch when the transmission is hot. I'm hoping it is the switch.
I tried googling to see if anyone ever had this issue yet but no luck. I'm always nervous of my diagnosis when I'm the first one to have a particular problem.
Any input anyone has is appreciated.
I've ordered the switch and if it fixes the problem I will update here so everyone will know.
Also, it looks like a crappy job to do!
13000 Kms
