bike: 2001 ZX9r
i dont know how i would have wrecked my motor.... i layed my bike down (see my other thread) and when i got up and brushed myself off, the bike engine was not running, so it cut off on it's own somehow
i tried to turn it over with the starter immediately after the wreck and it did turn over
2 days later now that ive started to work on it and i cant get it to turn over with the starter. i've got nearly all of the electrical stuff connected from where i disconnected it all to remove the subframe
here's where im unsure...
i have my bike up on a stand. i put it in 6th gear and tried to grab the tire and turn it to make the motor turn over (not trying to start it, just trying to see if anything is locked up) and i could just barely make it turn over. it was very tough. i had to use all of my force to get one stroke out of the pistons, even in 6th gear.
so i decided to remove the spark plugs to see if it would turn over easier
now ive worked on several 2 stroke motors, but not a 4 stroke yet. i know on a 2 stroke if you remove the plugs the pistons will spin freely in the cylinder.
when i took the plugs out of my bike i could just barely notice a difference as far as ease of turning the motor over by grabbing the rear wheel and pushing on it. it was still very very tough to do, hardly any easier.
im thinking the thick valve springs are still going to give some resistance as opposed to a 2 stroke. but should it still be that difficult to turn the motor over even though there is no compression?
