1 - 5 of 5 Posts
first I moved up from 30 mains to 35's. Pulled real nice but the plugs looked lean. Went up to 40's & lost power so I put in 37.5's today. Pulled better than the 40's but stuttered at 9,000. Like it ran out of fuel in the bowl. Anyone got any idears? I'm tired of playin with 'em, should I just get a V&H jet kit?
What upgrades have you done to your bike? 140s are only for if you've done air pods and full exhaust. Otherwise you should go smaller. If it pulls best on 135s I'd go with those. Or maybe find a set of 136 jets to use (dynojet makes a set). Individual jets shouldn't cost you much.
I'd say stick with the 135s if they pull hardest. The plugs could be because the midrange or float heights could be too lean.
http://www.factorypro.com/tech/carbtune,CV,high_rpm_engines.html
1 - 5 of 5 Posts
