1 - 4 of 4 Posts
well your jets depends ALOT on your location you fuel mixture the temp the humidty and various other factors all rolled into one .... the best thing to do is read ..... read......... read on how to jet and if at all possible find a friend that knows how to jet first hand and have him give you a hand till you learn what he is doing and why but here is a start for you
My Account - Profile Info
read that it will give you a good starting point for what you need but if you are having trouble with deciding what jets you need just rember allways start with stock and make ONE change at a time till its the way you like it ..... and once you get your bike tuned right youll LOVE it
let us know if you need any additional help
Since it is a two stroke there will be no stock jetting for the engine. Any competent dealer will have set it up for the climate, altitude and riding area in which it was purchased, and then it is likely that it has been rejetted any number of times since as riding conditions varied.
From your other post I see you are going to clean the carb, just order your new carb float kit from Beartooth (up in the header of this page) and have them send you both a jetting chart and the typical jets you will need in your area. Also, pick up a couple of new spark plugs. Then go to How you can read spark plugs and select them - by Gordon Jennings. and follow the instructions on how to read your plug to properly jet your machine. There is another site Spark plug reading that provides color photos of spark plugs for four strokes, the color you want is the same for both two and four strokes, but read the first site for the details on the two stroke.
What you will find is that ideal jetting will change from season to season, and if you ride in mountains where you change altitude you will need to take that into account.
On a two stroke, jetting for the best engine rpm and power is not always what you want to do, as that tends to run them lean and can lead to burning down the piston. So, pay attention to the jet chart and dealer's recommendation.
1 - 4 of 4 Posts
