Good morning,
I am a complete newbie with just basic knowledge of motorcycle mechanics. I do have good intuition and abilities.
I just picked up the bike a few weeks ago. Bought the repair manual and started teardown. The bike likely needs new pistons and rings along with just normal clean-up and replacement of worn parts, mostly old rubber like tires and trun signal posts. Other than that, it is is good condition.
Owner said that piston/ring work had been done incorrectly and needed to be corrected. I will find out more when I get there.
I am at the stage where I am trying to get the carb assembly off. Does anyone have any advise? It seems the carbs are attached to the engine with a centre post. I have all of the rings for each rubber connector loosened and am about to start removing the air box side. It seems to be the logical sequence since these are the only ones I can access to gain room to move the carb assembly around. The engin side hoses are made of stiffer rubber and don't have any give.
I look forward to hearing from anyone with experience on this fairly rare bike...
