1 - 1 of 1 Posts
hello
I just rebuilt my kawasaki. At first it would spin and spin with the generator bolt. THen I hooked up the starter and it would spin until it arrived at one point and stop abruptly at the same point each time. It would rotate and then make a thump noise. Also, it seemed as if the more i kept rotating it the further it would get each time and it would rotate longer. Now I cant get it to rotate. Could it be the top end rebuild was a bad job or that the spark plugs are hitting pistons? Thank you for any help you can give!
J
1 - 1 of 1 Posts
