1 - 5 of 5 Posts
I have a 2005 250 Bayou that leaks gas when it is parked. I pulled the carb off and put a new kit in it, but it still leaks. Any ideas ?
It leaks from the overflow tube coming out of the carburetor.
which means the needle is not seated or the float is bad not sure if these things even have a float ...... take the carb apart again. also does your fuel have an on off valve should be used when not running
1 - 5 of 5 Posts
