1 - 1 of 1 Posts
I have 2016 4010 mule 4x4 I have always have had problems with it Idling correct some times it would Idle and some times you would have to keep your foot on the gas pedal for it to run but as soon as you would let off the gas pedal it will die then it started to run rich you could smell the gas burning. then one day it just died and know it won’t run. You can disconnect the fuel lines at the pump and no fuel comes out I switched the fuel relay but still no fuel
1 - 1 of 1 Posts
