Hey,
I have a 1981 Kawasaki 440 LTD. I put my bike away last fall and it was running however now, when I try to start the bike up, I'm having issues. Here's the problem. When I turn the kill switch to "run", put the choke fully on, and press the start button, the engine turns over but the only action I get is regular popping sounds (like a mini-ignition) in the dual carbs, followed by exhaust trickling out the air intake (located under the dual seat). It's as if the bike is igniting the air/fuel mix in the carbs and sending it back out the air intake. However, when I turn the choke off and try again, I don't get any results at all (no start, no exhaust, just the engine spinning over and over again). I'm confused at why there appears to be exhaust coming out my air intake (the exhaust doesn't come out hard/fast, if just trickles out after each pop in the carb). Anyway, any help would be much appreciated. Thanks!
Kirk
Kirk
