New owner of a Kawasaki 600 thought someone might beable to answer this question. The hour meter stopped working at 5.1 hours.The meter display has 5.1 on it but has not moved in 2 hours run time. I can take it back to the dealer were we purchased it. Thought someone might know if this is a simple fix.
Usually it is a wire that has shaken loose when the meters quit at low hours. Trace out the wiring and you will probably find the problem.
