1 - 6 of 6 Posts
Hi i have an old Kawasaki Aircraft B8 and looking for info on what 2-stroke mix it should take and what recomended oil should be used in the gear box?
Thanks
Carl
Super Moderator
For premix oil I would suggest:
Any good quality, motorcycle oil should be ok for the tranny/clutch. 10W-40 should be fine. Here is one example:
Thanks for that. do you know what the premix ratio is for this 50:1 or more 25:1 last ting i want is to cause damage to the engine due to incorrect mixture its lasted this long don't want to kill it now lol.
Super Moderator
I would use the premix ratio as indicated on the bottle or perhaps slightly richer. Modern oil is vastly superior to what was available back in 1965 so even if you had the original owner's manual, those ratios would not apply to modern oil.
So if the bottle says 50:1 I would suggest going to maybe 40:1. Also, use high test gasoline to avoid ethanol.
1 - 6 of 6 Posts
