MongooseMachine.com or qande.com both do good work. Both carry Wiseco pistons and rings, so once the bore is complete you will get first rate components.
If I recall correctly, both can take you up to around 220 cc for the same price as the 185 rebuild.
If the cylinder wall is clean and not tapered or eaten out, all you need is the piston and rings, try wiseco.com.
