1 - 6 of 6 Posts
Have a bayou 185a have replaced both primary and secondary clutch’s but seems to be still slipping 1st gear and reverse pull well.. but 2,3,4,5 the quads revving out and not pulling .. has anyone any ideas of what could be wrong ?? Thanks
Discussion Starter #3
Yes I have played about with the adjustment screw it’s seems it just makes the gear level harder to select gears ??.. as in the gear pedal either gos floopy or hard to select.. the belt your referring to ? We’re is this
Did you replace all the parts of he primary clutch or just the shoe assembly or?? Did you soak the shoe assembly in oil for a while before putting it in?
You don't have a belt.
Discussion Starter #6
Yes replace all working parts of the primary .. the pads or shoes that I took of we’re done no tissue left on them the new ones I put in were more or less brand new
1 - 6 of 6 Posts
