Hi and welcome brother biker, that absolutely beautiful F7 takes me back, this was a 175cc dual-purpose motorcycle manufactured by Kawasaki from 1971 through 1975 and looks in stunning condition; hope you keep that a supreme intellectual F7 in the rank of masterpiece........ You have a great evening my friend..Absolutely beautiful F7. That model is equipped with the Hatta fork, 3 axle positions, center or stock location, forward as it appears to be now, or turn the fork legs 180 degrees for a rearward location. This was clever but I found the alternate locations to be far to extreme. I have ridden the F7 with the axle located in all three positions, the forward and rearward locations produced a very strange handling motorcycle. If you have not already done so you may want to try the center position. Good luck and I hope you can preserve the motorcycle in that condition.
A quick question. I looked all over for the correct amount of oil to refill the forks (did a seal replacement). Do you have a service manual that mentions the correct amount. I'm seeing either 130cc or 175cc but would like a definitive answer.These F series bike are a ton of fun! Over the last couple years I've rebuilt a 1971 F7 and a 1974 F7, so if you have any questions, a lot of info should "still" be in my head. I'm just getting ready to put together a 1974 F11 too, so I'll be back at it in spring.
These F7 forks are not the best, but standard oil is a 10W at 175cc (+/- 10cc) for oil quantity. You can experiment with heavier weight oil (or even ATF fluid) for different damping action.A quick question. I looked all over for the correct amount of oil to refill the forks (did a seal replacement). Do you have a service manual that mentions the correct amount. I'm seeing either 130cc or 175cc but would like a definitive answer.
You should definitely plug the vacuum pump located on the front of the case (see photos). As well, put a cap on the corresponding port on the carb too. This vacuum pump is notorious for air leaks, and is the case of many headaches! Just remove pump, fill hole with oil resistant gasket sealer, and then bolt pump back on, it is non-working now, but is just there to cover the plugged port.View attachment 44941
I picked up the exact same bike only in much worse shape.
I was able to get it running by replacing the crushed carb float.
I'm working on restoring it now, its in pieces but i'm getting ready to put it all back together
I'm no expert at this, its actually my first restore, whats some "basic engine maintenance" before i start driving around on this bike?
Carbs cleaned, going to test the pump out, by dissconnecting it and using 20:1 in the gas tank while making sure the pump is discharging .186 fl ouces per 3 minutes at 2000 rpm
I'm hesitant to crack open the crank case but i bet there are some bearings in there that might need some TLC.
I only had a chance to rev it up not ride it.
I cleaned and oiled the forks, got new tires and cleaned up the rust on the wheels new air filter and box...
what else do you all recommend...
