Case scrubbing time... a toothbrush and parts solvent.
Kevin Bergeron says one should only use the blue "Scotch Brite" scrubbing pads on the gasket surface (he says the green Scotch Brite pads will scratch up the naming surface and shouldn't be used).
Comments anyone?
We also have an oil seal that doesn't seem easy to remove, I don't want to marr up the seal housing on the case... I know there are seal pullers one could use.
Comments anyone?
