Yes, one place quoted $100, another place $65, a third place $75 (for just the crank rebuild labour, I supply the parts).Did you ever get a quote from the other crank rebuilding places you contacted?
Would it harm the aluminum? It's only 5% acetic acid...I have never used vinegar for cleaning carbs but I can recommend it on french fries. 😁
Can I use vinegar to remove the chalky deposits in the carb?
Have to check out www.partsnmore.com for some electrical connectors. Thanks.Last night, I purchased a gasket set for my engine from "PartsNmore.com" for what appears to be a good deal. I bought a carb rebuild set too, total cost just over $80 CAD including shipping. Comments? Anyone deal with this part supplier?
The parts are for the 1976 KV100, I crossed referenced the parts and they appear to match up. I hope they match my bike.
Engine gasket set:
Carb kit:
I'm taking a chance, I hope they work for my bike.
Kevin Bergeron's YouTube channel has a pile of videos on spark/magneto/points/condenser troubleshooting.Have to check out www.partsnmore.com for some electrical connectors. Thanks.
I have to follow this build thread. I am working on a 1976 KE100 my son picked up for $200 last summer. At least our piston turned over with the foot pedal. Electrical has been our issues. When the seller states "no spark" we should have walked away. We were going attach the exhaust to the bike a couple of weekends ago but discovered a broken bolt or stud at the exhaust port. Need a heated garage. Winnipeg at -30 is not to pleasant.
I've been following Kevin's youtube channel since we got the bike.Kevin Bergeron's YouTube channel has a pile of videos on spark/magneto/points/condenser troubleshooting.
I bit the bullet and bought a used carb on eBay. Paid much more than I wanted to, but that's the way it goes I guess.Drat... I've found a hole in the float bowl... now what? Do I try and patch it?
He has so many of them.I've been following Kevin's youtube channel since we got the bike.
I hear you. I've cancelled my eBay transaction and am going to try the Chinese carbs.Some people have bought the cheap Chinese carb knock-offs and have declared them as junk. Even when replacing just the carb jets, there are cheap jets out there and there are good jets out there. I think generally you get what you pay for. Buyer beware I guess. Do your due diligence.
