1 - 6 of 6 Posts
HI THANKS FOR READING GOT MY FIRST BIKE LAST NIGHT EVERY THING WAS FINE COMING BACK ,CUT OUT A FEW TIMES PUT THIS DOWN TO INEXPERIENCE AND BEEN A NEW BIKE. HOWEVER WHEN I GOT HOME AND STARTED UP AGAIN MADE A FUNNY POPPING NOISE, REV COUNTER WENT CRAZY SO I TURNED IT OFF. WHEN I TRIED TO START AGAIN NOTHING, NO LIGHTS NOTHING, CHECKED FUSES UNDER SEAT, THEY OK, TRIED TO TURN OVER AGAIN OIL LIGHT CAME ON,HOWEVER NOW THE STAND LIGHT NEUTRAL INDICATER AND REV COUNTER WONT WORK, ANY SURGESTIONS WOULD BE GREAT HAVE ALL READY ORDERED HAYNES MANUAL
Sounds like you'll need to go through the wiring loom from top-to toe m8.
There are either some badly bodged connections or a lot of corrosion.
Don't try to start it again 'til you've had a good look else you might bollox the IC-igniter or cause other damage.
The Haynes will guide you (slowly) through it :)
TO LATE NOW THE BRAKE LIGHT PARKING LIGHTS ARNT WORKING ONLY BROUGHT THIS BIKE A FEW DAYS AGO DO I ANY RIGHT TAKING IT BACK IT WAS SOLD AS SEEN THINK THAT ****ERS BURNT ME
Ooof. If it's sold as seen you might be in trouble, might work to appeal to the sellers better side.
If all else fails you might find the root of the problem is nothing major, give it a go.
every think looking better popped round his house not a wiring fault .instrument panel is broke the millage was recording but speedo and rev counter had stopped with the stand light and neutral light so onto ebay for a new dash oh need new plugs to and fuel sender unit and rear tyre the joy of having a new bike with so many problems for my first bike
1 - 6 of 6 Posts
