1 - 13 of 13 Posts
Discussion Starter #2
So, no fuel getting into the engine, or through the carb we鈥檙e geussing. Cleaned the carb completely replaced all the jets etc. New spark plugs getting good spark. Fuel is getting into the bowls as when I loosen the screws fuel comes out. Anyone got any idea as I feel like I鈥檓 missing something haha
Spray a little starter fluid into the intake and see if it starts. If it does, that probably proves there is a lack of fuel problem.
Discussion Starter #4
So we done that and it kicked up instantly, there鈥檚 no fuel getting through the carb, having no air filters might be a factor right ?
It sounds like the motorcycle has individual pod filters. or will have them. Do you have the stock airbox? If so, I would install the airbox w a new air filter. and check & set everything as per the factory service manual. troubleshooting isn't my forte, though, and don't relish the idea of trying to chase down why it won't start.
Discussion Starter #8
Yeah so fuel does flow into the carb as I鈥檝e pulled it off and tested it, il have a another go today by putting the air filter box back on. Maybe it鈥檚 getting to much air with the choke opennmight try it with choke closed
A good place to start with the idle mixture screws is about 2 full turns off bottom. My ZN700 that I bought in 2009 with only 1,054 miles on it had the idle mix screws set at 1 1/2 turns off bottom and that seems to work well so I never changed them.
itching to ride
It's probably not going to start without the air box on. CV carbs are like that.
At start up and at idle, it makes little difference if the airbox or pods are in place. The upper end of the rpm range will show the lean condition caused by pods or no air filters and not so much the pilot or enrichener circuits. If there is gas in the bowl, engine vacuum will draw this gas in if the pilot jets are clear. Did you install new pilot jets? In any case, running pods on Teikei carbs isn't a great idea as larger pilot jets or main jets, for that matter, are hard to come by. They can be had but the jets in a jet kit are stock size and won't do well with pods. I would stop looking at the carbs for the time being and look at valve clearances; sounds like there isn't any.
itching to ride
Yeah I had seen them not start with a naked carb but likely they had other issues as well.
I just got through installing new jets in mine and tried starting it without anything behind the carbs and it fired right up. It did not take the gas that well but idled ok.
I will update my thread on pods a bit later as I just finished going that route. Well almost finished. I am in the tuning stage atm.
1 - 13 of 13 Posts
