my 610 runs fine but not charging, this is a used machine had it for a few months now, checked fuses by battery glass in line, they are good, one think I also notice both the park brake and oil temp lights do not work.
the last owner has installed a full size battery under the seat to replace the original, he extended the original battery cables to reach the car battery.
plug is pushed in place on rectifier or regulator, its to left of original battery bolted to the steel frame, what is the item covered in rubber shield besides it, wires coming out the bottom?
where to start to figure it out? can the voltage from the magneto/generator be checked
