1 - 5 of 5 Posts
Need some help guys. My head light quit working and I don't know what the problem is. I changed the bulb but it still does not work. Is there something else I can look for?
The low beam burned out on my 2007 Yamaha Royal Star Venture so I decided to upgrade to a Sylvania ultrabright bulb. That bulb burned out in a few seconds on both the low and high beams. So, I went back with the standard bulb. I thought maybe the charging system was allowing the voltage to get too high but no, that wasn't the problem. Just the bulb.
  • Like
Reactions: WFO-KZ
Super Moderator
Also your bike may have a headlight relay which may be at fault. Did you check the bulb to see if was really burned out?
1 - 5 of 5 Posts
