hey i have a 93 kdx 200, i need to replace the seals in the forks, i have the spacers and the springs out but i am having trouble seperating the two tubes so i can change the seals, any suggestions on why i cant get them out or any ideas on how to do it? thanks
If you have a service manual it should tell you how to get them apart. Use the Search function and look through some of the hundreds of fork rebuild threads on the forum and you should be able to find a solution. You might also want to look at the parts breakdown at Kawasaki.com for your forks so you have an idea of what is holding them together.
A quick looks at the parts breakdown shows a snapring under the seal.
