Hello. Maybe I should post in the mecahanic forum; IDK. I'll try here.
This is a US GPZ600R; the first "Ninja" model, as I understand.... 1986 steel frame. Imported to Norway, and sold used here.
Okay. After some troubling times, I got hold of a new fueltank last year. After cleaning the carbs, but still experiencing some low speed (under 3500 rpm) stumbling, I get hold of new PILOT SCREWS. Unfortunately, I forgot to count numbers of turns out, but after reading up, it seems 1 7/8 of a turn should be OK. They are right now out only 1/2 turns.
The Pilot screws wer about 1 1/2 turn out, and I was experiencing RPM not going down to idle when i released the throttle. Freed the cables and mechanically the carbs closed fully, but it took some time befor RPM's went down to normal. I suspected TOO MUCH FUEL, and therefore closed the pilot screws and tok the 1/2 turn out, only.
Now I'm experiencing an idle problem; need to open the blades to "full" with the idle adjustment screw. And then, randomly- the rpm suddenly rises to 4000 rpm or more, then slowly goes back to the normal 1300 rpm or so.
This also happens when starting (the warm) engine; rises to 4-5000 rpm. If I then turn the idle speed screw to lower RPM, the engine will stall, and I have to turn it to the max setting, where it idles somwhat steady- for a while.... Until it rises once again....
Today I checked the (large) fuel filter I have on. It's clean. But I noticed the filter compartment is NOT fully filled with fuel. I have no fuel starvation on higher RPM's either. So; I'm a bit stuck here.....
If you have a clue to whatever faults my carbs can have- I'd love to hear it...
Thank you very much
Rune
Thank you very much
Rune
