1 - 2 of 2 Posts
We bought a couple KFX 700's. Would like to know what is involved in an oil change. What type of oil, filter etc? How much oil? Synthetic? Weight? Any other things to do? Grease zrt's etc.
We bought them used so no owner's manuals etc.
Thanks
usually it tells you on the engine the capacity next to where you fill it, I run 10w30 and I get fram filters for it from walmart. I don't run synthetic. I would just assume change the oil more often. You are going to want to change the rear diff fluid and you will need to by that from Kawi. I don't have the that atv but the Prairie is the same powerplant and drive train. Not sure about zerk fittings mine has none
1 - 2 of 2 Posts
