so i trying to figure out my kickstart problems. kickstart grinds and binds when i go to start it. so i pulled the clutch cover off and check out the kickstart. right away i see metal shavings on the kickstart gear. not good, so me next step is to remove the clutch basket, but i don't think i have the right socket as of now, so i need some advice on putting this thing back together. does the clutch nut or water impeller nut need to be torqued on? or just run them tight? figured i post this now and get things straightened out before i go to finish it. thanks
