Ok well first of,
Hello
new member here, newish anyways. My machine is a bitsa really. not junk but made up of a few bikes and its a headache at times.
The parts:
'89 KX125 frame
'88 KDX200 motor
'90 KX250 forks
wheels from 90 kx at front and 90 kdx at rear.
its been very well built and you'd think it was made this way from new. Rides off road a charm and has seen some pretty big gaps too! however the overly large cast iron kickstarter has finally slogged out so much that i cant take it anymore. In New Zealand where i live these older parts are somewhat rare and would like to know if anyone could tell me what later model aluminium kickstarter will fit the spline on the shaft? have tried 90 CR125 and the shaft diameter is the same but the honda has a much larger spline than the fine one on the KDX.
If anyone has any suggestions it would be much appreciated.
Discussion Starter · #2 ·
well nobody helped but i found one anyway. a honda NSR lever and boss with the pinch bolt welded shut and ground off is perfect.
Motorcycle Momma
KX200,
I apologize for the lack of answers. I would like to welcome you to the forum....I hope the lack of responses didn't scare you off.....glad you found the part you need.
I hope that you come back again. We do have a lot of fun up here.
Heather
