I have recently purchased a 2006 FLF 300 4x4 and I am hoping somebody can help me with a couple of queries. The first one relates to the gearshift. With the Neutral light on I lift the gearshift but there is now engagement or “click” as the gears mesh, but as soon as I give it a little revs while I am still lifting the gear selector it engages gear. Once on the move it runs through the gears fine. Is this correct. The same with the reverse, I have to give it a little revs to engage while holding the reverse switch.
The second point relates to the low range gears. I pull the low high lever back from high to low and set of fine, but the ratios appear to be the same. Again is this correct as I was expecting the low range to be almost crawler gear.
