1 - 4 of 4 Posts
I have installed 1 1/2 dogs bones,however after loosening triple stage pinch bolts/nuts(finger loose) and front axle nut I am not able to get the frame to drop down the shafts. I have wedged large screw driver into cap trying to release preasure, I have tapped the handle bar frame with wood/hammer, sprayed wd-40...still no movement. bike is off the bike jack, with both wheels firmly on the ground. I have tried to bounce the bike by sitting on it, grabbing the handle bars...
help !
MX. Dad and Racer.
You need to take the front wheel off , are you trying to drop the fork tubes?
Its much easier to do with the wheel off , one fork tube at a time.
By any chance did you also loosen the front shock boots? When I lowered mine, that was the only thing hanging it up. Hope this helps.
1 - 4 of 4 Posts
