1 - 5 of 5 Posts
I want to lower my 2020 klx 300r if I install the lowering rods for the back 2 inch's and drop the front forks in the triple tree 2 inches how will that affect the handling of the bike.
I did exactly that to my KLX300. :)
I installed Koubalinks on the rear. (gold links)
Tire Wheel Fuel tank Automotive fuel system Vehicle
Then I slid the forks up on the triple to lower the front. I also installed lightweight alloy clip on bars directly onto the tops of the fork tubes.
Automotive tire Vehicle Automotive lighting Motor vehicle Automotive exterior
Motor vehicle Gas Auto part Camera accessory Telephone
Automotive tire Automotive mirror Motorcycle Motor vehicle Automotive lighting
Plant Plant community Motor vehicle Automotive tire Automotive lighting
I can easily flatfoot both feet with my knees bent when stopped, and the lowered chasses corners really well with both the bike and the rider closer down between the axles. :)
(Notice the rear swing arm is parallel to the ground.)
Wheel Tire Helmet Motorcycle Automotive tire
1 - 5 of 5 Posts
