1 - 5 of 5 Posts
Life Saver
A friend and i are trying to install these on a 900 custom with the stock wiring and equalizers. The turn signals work fine but when we hook up the hot for the running lights, it all stops except for a weak pulse turn signal. Anyone installed these or can help with what we did wrong ? Seems to be a ground issue but cant figure it out....thanks in advance
Life Saver
Trashman.....i have read the other post but still a little confused. Did u instal the diodes between the 20 pin connector and the cluster or before the connector? Kind of stumped here if u can offer a little guidence on what u did. We have already changed the flasher to electronic and when we take the test light and ground it to the battery and touch the gray or green,it flashes fine but no running light? Am i confusing you now ? lol
1 - 5 of 5 Posts
